Swapping the final drive ratio is just swapping out the gears. In fact, I think you can buy aftermarket final gear ratios that are steeper yet.
Another option to get the 4.266 final gear ratio is to buy an Accord wagon manual transmission. They had the exact same 1st to 5th gear ratios as the sedan, but came with the 4.266 final drive instead of the 4.06. However, there weren't many of them made and I've been looking for one for a year without success. Tranny codes are H2U4 (4th gen) and P2A4 (5th gen).
However, swapping 5th gear from an Accord to a Prelude tranny is not as straightforward. 3rd-5th gears are designed as a set, so swapping 3rd-5th would just be a gear swap. However, the Accord 5th gear is a bit wider than the Prelude 5th gear, so to swap 5th gear only you have to shave the Accord 5th gear down. People have done this. However, when I worked at Honda 10 years ago I had access to the powertrain experts and they advised against having this done, as the gear is case-hardened and shouldn't be milled.
