i had an issue with my brake lights staying on. until i figured out what was wrong and fixed the problem i just disconnected my neg. battery cable wherever i went. turned out the little rubber thing that hold the brake switch depressed all the way had broke off. so i just put a screw in it's place.
so now that my lights are not always on, i figured my cruise control would start working, but that's not the case. check the fuse and it was good, but i don't know what else to check to get it working again. the little button you press on the dash glows green when cruise control is on, but when i press the button on the steering wheel nothing happens.
so now i'm not sure where to go from here.
