All doors open problem
    i can't figure out why it shows all doors open when all the doors are closed. i checked and filled steering/braking fluids/clean and checked each door latch ..
    Problem
    Your door ajar sensor probably has dirty contacts. There is one for each door, near the latch on the body.
    It has one phillips head screw and one wire behind it. Pull em out, take them apart and clean 'em really good, and your indicator lights should function normally.
    Does your dome/courtesy lights stay on because of this?
    '91 EX 280,000 || '90 LX 330,000
    _____(me)__________(wife)___
      that's not it. i had this problem with my car when i first got it. the dome and door lights didn't stay on. it doesnt do it anymore and i don't remember if i even did anything to fix it lol. one day i just got in and noticed the indicator lights weren't on. never had a problem with them since.
        If all of your indicator lights are on (ie..trunk open, brake lamp and doors) read the thread below. I had the same issue.
        http://www.cb7tuner.com/vbb/showthre...or+ajar+lights
          i had the same issue my problem was a bad ground to the gauge cluster. the one on the drivers side kick panel came loose.
            Now my damn maintenance required light is on! Last time this happen I had to pAy 200 for an alternator
              The maintenance required light is just a mileage counter.... Turns red about every 7500 miles or so, if I remember correctly....
              92ex CB7<-SOLD 93ex CB9shiftingshift73C10
                yea you were right.
