i am reposting some of the same info that i had posted before the site went down (which is now gone forever)
^info i had posted before
now YES i fixed the oil in the spark plug holes. i replaced the lower spark plug tube seals and of course all other seals AND spark plugs. (borrowed a torque wrench) the Distributor however has not been replaced. i have yet to find a NEW or REMANED dizzy for less then $100 and i just can't afford it right now. i pray everyday that she will keep going till i can afford one.
now i have video of what the RPM's do going down the road with the cruise control set if anyone wants to see them.
my NEW question is: is there a way (with the way the RPM's jump and how she boggs down) that the timing belt can jump and cause even more damage? thank you all in advance for any input you have.
driving down the road at a steady speed the rpm jumps up and down about 200-300rpms. it also boggs on acceleration. oil is leaking into my distributor all over the ignitor and have oil in two spark plug holes(FIXED). O2 sensor is unplugged. any and every suggestion would be helpful. thank you all in advance.
(and i will most definitely update this with the solution to my problem)
