Part ID Help
    Part ID Help
    Under the driver side fender is a black cylinder lookin thing that has a vacuume line connected to it that T's into the cruise conrtol and something else inside the engine bay.
    What is that and will it hurt anything if i were to remove it?
    Anybody?
    I need a quick answer please
      If its connected to the cruise control you might lose or not have the vacuum presure when you try to use the cc. Pics would help to see what your talking about.
      Sold to:
      GunRunner,mtnickel,SanJoCaF22DrAcc,sikz6,daovangph otos,megarock15,
      Purchased From :cb95spd,"sleepin"
        Probably a one-way check valve, but would have to see it to confirm this. It was put there for a reason, and probably wo'nt hurt anything if you make sure to put it back on.
          Picture is up
          It appears to just be a hollow chamber with a vaccum line connected to it?
          I intend to remove it and not put it back on, this is why i have the question.
          any ideas?
            i took mine off.
            COUPE K24
              Originally posted by WagonLX
              That is the cruise control actuator, and removing it will cause you to loose cruise control.
              Hmm, looks like nothing to me.
              Oh well its goin in the trash then! lol
              Thanks guys
                After you took it off, does your cruise control still work? I have no idea what that is or does. Sorry
                  I ended up taking the cruise out completely.
                    I've always heard that's the equivalent of a vacuum accumulator.
                    MRT
                    sneaky motherfucker
                      Its a vacuum reserve chamber, Think of it as a storage tank for vacuum. If it wasn't there then you would lose all vacuum at wide open throttle. (The reason mid 90s dodges lose climate controls under load) If your running without the cruise then trash it and don't look back. It is only there to provide stored vacuum for the CC diaphragm.
                        oh nice to know..i wondered what it was when i ripped it out
