Ok hmotorsonline advertises 2 F20b's. A 200hp manual version, and a 180hp automatic version. My question is are these motors actually specific to what they say auto and manual. Can I use the 200hp one for both my auto and manual. Or do I have to buy the lower hp one for my auto.
F20b's DOHC VTEC
IIRC the reason for the difference in HP rating has to do with the gear ratio of the transmissions. The F20b engines will bolt up to, and work with, any F/H series transmission. Now will it run properly on an F22 autotragic trans....I'd vote probably not the best match. Long gears with a high rpm lower displacement engine will work. but the gearing is a bit off.Last edited by GhostAccord; 01-10-2012, 01:45 AM.
Yep, and there is another difference too between those and I can't remember right now.Originally posted by jamaicancb3 View PostWait, pause. Isn't it not that the Manual version which came out of the CF4 SIR-T had bigger cams, compared to the auto version which came in the SIR with smaller cams. i thought gear ratio was only a torque multiplier
But essentially the only reason this was a production engine in Accords was to get into a certain touring car class for racing.Gary A.K.A. Carter
[sig killed by photobucket]
You may have a point there. However, it's a 2.0L, how much bigger are the cams going to be for 20hp? I'd say it's probably more in the tune.Originally posted by jamaicancb3 View PostWait, pause. Isn't it not that the Manual version which came out of the CF4 SIR-T had bigger cams, compared to the auto version which came in the SIR with smaller cams. i thought gear ratio was only a torque multiplier
I have read a lot of hear say, about the T being bigger aka H22 type S cams. However, I have never actually seen anyone post up any cam specs comparing the two. Anyone care to share?
As much as people want to think the A6 cam is so much bigger than the A1 & A4... You would be surprised by how little they differ. That being said. They are different and they get different results and that's all that matters. You still need the ECU/tune to get them there!
IIRC The F20B wasn't really for the touring class racing with these Accords. It was more to keep them in a sub 2.0L tax class for sales in certain countries.Last edited by GhostAccord; 01-10-2012, 02:45 AM.
I know that's what the Wikipedia page says but I don't know if I agree with that. It was available in Japan right alongside other Accords that had H23A VTECs in them. And with an 11.0:1 compression ratio along with a very decent valvetrain it would only make sense that the motor had racing intentions inherent in its design.My Members' Ride Thread - It's a marathon build, not a sprint. But keep me honest on the update frequency!
I believe the lower-hp automatic version makes the majority of its power lower in the RPM range, making it more useful for an automatic, which won't be revving to redline constantly. It has absolutely nothing to do with the strength of the transmissions, and a healthy, properly maintained Accord automatic will be able to handle the stock output of any H or F engine you can bolt to it.
Of course, as mentioned above, you may not want to deal with the gearing... as the Accord's long gearing could sap the fun very quickly.
Honestly, I'd skip the F20B and just pick up an H22A. OBD1, no non-USDM mystery parts, and although the to motors are very similar, the H22A is documented much more thoroughly on the internet.
i vote h
im with deeve on this h22a more no how around thats a kinda (raare kinda) ok maybe but theres alotta potential in the f20 i love it but its just so much like my girlfriend a pain in my asss!!!i dont know why this popped up but U MAD BRO? not my fault u is FAKE! CLOWN ASSOriginally posted by deevergoteThis thread is over a year old, you fucking retard.
why swap upper plenum?
I don't know why you would be swapping upper plenum.
Anyway it is up to you, but the cost is a little higher if you pick up the ecu with it. It is cheaper then the h22, but remember you need OBD1 dizzy, ecu, and you need to do OBD1 to 2 conversions. This means probably going OBD1 so chipped ecu and a tune before you can even turn it on.
If you are using it as your primary mode of transport I do not recommend, because parts may be a ways out if you need them.
As for the cam thing, I bet deev hit the nail on the head. It would be very interesting to get peak torque rpm for both and also see how both came do with cam gears and some degreeing.
I just checked, not sure where you are getting.g your prices, the h22a OBD1 is 999. The manual f20b is 849. So you are "saving" 150 bucks on the f over the h.Last edited by Ghetto_CB7; 01-11-2012, 01:30 AM.
