Valve cover gasket
    Valve cover gasket
    Ok so I went to the dealer to get the valve cover gasket but they wanted 25 bucks for it so i was looking on rockauto to see what other options are available, and there are quite a few. I was wondering which one of these gaskets do you guys recommend?
    A 25$ valve gasket is not a bad deal plus the OE honda one will ultimately fit the best. I know when I rebuilt my head I used all OE parts and gaskets/seals. These parts were designed by the OEM that R&D'd the car you drive so they are the best (for a stock rebuild).
    If you really must buy a cheaper gasket, any Autozone or Pep Boys etc. will carry a gasket for it that will fit just fine, just add a little black RTV silicone to the corners (where ever the gasket has a 90degree bend like where it goes over the cam). Make sure you get a gasket that comes with, or get seperate, the grommets for the top (4) and the spark plug seals in the valve cover on the back side(4).
      I just replaced my upper and lower seals (leaking oil into spark plug wells, its all dry now :P) dizzy gasket and valve cover gasket, and the oil pan gasket. I used all oem honda replacements to do the job. That was in november and everything is dry and clean. It may be a little more expensive but I think it is worth it.
        ^^ I deffinetely agree!!
          Well you guys do got a point, oem is better, but how important is the RTV silicone? Cuz when I changed my lower tube seals and adjusted my valves, I scraped all of it off where it used to be. I mean the gasket still seems good(its still flexible and not dryed up or brittle) so it could be this right? I mean I wanna do things right and make sure it stops leaking but if I could avoid spending those 25 dollars, id rather spend them else where like a new fuel filter or something.
            U shouldn't be using silicone on those lower or upper tube seals. I don't use it period on the valve cover and I've changed many of them and never had any leaks at all. Some cats throw a dab or two on the corners and whatnot tho.
              Us "cats" that apply Hondabond to the cam cap area do so because Honda does so and specifies it in the service manual.
                I was talking about the corners of the valve cover gasket.
                  ^^ Yea its just a little added security
                    The cheap gaskets are a pita to get to seat right without the rtv. They seem too big fresh out of the box. If you want to avoid spending the money, deal with the leak!
                      I just got done saying people use the shit on the corners, whenever u get thru runnin your meezy. Didn't nobody ever questioned the use of the silicone.
                        Use OEM Honda, or you'll do it again.
                        MRT
                        sneaky motherfucker
                          Just making sure, they dont sell oem on rockauto right?
                            I just said people use silicone on the corners. I don't, but agree that it should be done. I never really questioned the use of the silicone.
                            Fixed it for you!
