90mm h22 block
    90mm h22 block
    Hey guys,was wondering what you guys think about a darton sleeved block with 90mm pistons.Reason for asking is,i can buy this setup but i want to boost it.I have all the turbo parts I need.I know 90mm is usally used with n/a.Just wondering if it can be boosted without any problems.Thanks in advance.
    Anybody have any opinions?
      Probably not a good idea for boost. There's a reason Darton doesn't bore to 90 for turbo applications.
        It certainly isn't IDEAL for boost, but for the sake of understanding what your goals are a bit more, I want to know your specifics.
        What amount of boost do you intend to run?
        How much will you be getting the shortblock for?
        And I guess I should ask if it is indeed a complete shortblock.
        Is it a 50mm or 55mm main block?
        If your goals are to boost below 15 pounds then it shouldn't be much an ordeal. Typically people who want to sleeve a block for boost have goals set a little more lofty than 15 pounds so the recommendation to stay 89mm and under is with that consideration in mind.
          I guess i got my answer.Thanks for info.The block has sleeves and h23 crank.the guy has some misc stuff and 90mm pistons.He wanted 1,500.
            That sounds like a build I would be a big fan of. A bit on the expensive side though considering you're buying someone else's project.
              What pistons and rods come with the block? $1,500 for a MID sleeved bottom end is a pretty good deal. I would N/A that bish all the way!
              MR Thread
              GhostAccord 2.4L Blog
              by Chappy, on Flickr
                My thoughts exactly. But since he was looking at it from a boost perspective I would assume it had boost friendly pistons in it. But that setup would be right at home in my car.
                  Yeah I try not to ass-u-me anything these days.
                  Knowing what the cc of the dome/dish and the compression height of the pistons would be useful info.
                  MR Thread
