idle
This topic is closed.
    idle
    I fix my idle the other day to 700 rpms. and now every time my rpms goes up and down until i fix the idle again it goes away. what can the problem be??
    When you say it goes up and down. Do you mean the rpm is jumping from 0 to around 700?
    Everyday is one day closer to completing my cb7 <3
      sounds to me like your pissing off your iacv, how did you adjust your idle? there are 3 ways to do it 1 not correct but ive seen many do it
        its going from 700 rpm to about 2000 rpm
          i move that lil screw thats on the throttle body
            You're not supposed to just play around with that screw, its supposed to be adjusted then left alone.
              http://www.cb7tuner.com/vbb/showthre...t=erratic+idle
              Follow this DIY, which was found by using the search button and searching for threads with " erratic idle " in the title.
                Fitv
