Squealing noise when car starts
    When I start the car when it's warm or cold it makes a squealing noise. I think it might be the timing belt but I am not sure. Any suggestion?
    It's one of the accessory belts. The timing belt will never squeal. It has ribs so that it doesn't slip unlike the accessory belts.
      The timing belt won't squeal.
      OP, look for acc belts, then check for bearings.
      MRT
      sneaky motherfucker
        Originally posted by GeoffM View Post
        You are wrong. The timing belt won't squeal.
        I said they won't squeal so how am I wrong?
          Thanks
          Thanks for the help.
            There was another post in here and I had it quoted. It "disappeared" but my comment didn't
            I edited it, but not in time. You are correct.
            MRT
            sneaky motherfucker
              Ya i deleted the post because your answer was correct. I thought mine was right ,but after I saw yours i realized I was wrong so i deleted it.
              cb7sk8rdude
                Where should I look at to find the belt or where is it located
                  It's one of the belts you can see as soon as you open your hood. AC/Alternator or Power Steering.
                  They may be too loose, too tight, or simply too old. If you don't know what you're doing to replace them, it's not an overly expensive thing to have done by a professional.
                    Ahh ok haha You had me confused there for a second, I was rereading my post to see if I had some kind of a typo.
                      Mine does it too, right on start up for like a second.
                      Does your car have ac?
                      If not it is power steering.
                        Belt is just loose or worn.
                        Try adjusting it first. Visually inspect it for cracks, abnormal wear or other defects. If it looks pretty ratty, replace it.
                        The noise a timing belt will make is ugly.
                          how old is your timing belt? if you're worried about it I'm assuming it needs to be changed?
                          '94 CD5 EX F22B1 Automatic
