I drive a 92 lx all stock except for an sri. I was on the highway for 278 miles and filled up all the way to 7.2 gallons which comes out to about 38 mpg. I figured this could be an error on the pump but ive achieved 37 mpg before. Not that this is a problem but is there any particular reason it can come out this high?
38 Mpg?
You drive like Ms. Daisy, and you never do more then 55/60 on the highway?Originally posted by f22a192lx View PostI drive a 92 lx all stock except for an sri. I was on the highway for 278 miles and filled up all the way to 7.2 gallons which comes out to about 38 mpg. I figured this could be an error on the pump but ive achieved 37 mpg before. Not that this is a problem but is there any particular reason it can come out this high?
You should check out this site: http://www.ecomodder.comOriginally posted by BlitzCB7 View PostAny way to improve MPG on an H without hurting performance? Other than having to drive like Ms.Daisy lol.
Question: Are your rims and tires OEM spec?
If not, your odometer may be wrong, causing your MPG calculations to be incorrect. Also 'topping-off' your tank will throw off the calculations even more...just food for thought here.
38mpg does seem high, but not impossible. We have a 17gallon tank. I usually average 425miles from fill-up to low-fuel light...Mixed driving.
yeah 14" steelies and my odometer was right because the gps also said 278. I also never top off. One thing i did notice was that the engine temp gauge was on the line towards the c.Originally posted by Function>Form View PostQuestion: Are your rims and tires OEM spec?
that means your thermostat is broken. Its stuck open causing you to overcool your engine. You may get even better mileage with the engine in its proper operating temperature.Originally posted by f22a192lx View Postyeah 14" steelies and my odometer was right because the gps also said 278. I also never top off. One thing i did notice was that the engine temp gauge was on the line towards the c.
I had this same thing happen to my daily cb7. The temp needle just barely got over the C. I bought a Honda thermostat with gasket for about 26 bucks.
