Okay here is my problem and hopefully someone has an answer. I did the H23 intake manifold swap but haven't hooked up the black box to the ECU yet. (The plug is in but I ran the wires to power and ground to keep the butterflies closed) That being said though isn't the problem I am having. My problem is that the engine is surging until it gets warmed up then will stop. I don't have any vacuum leaks and everything seems to be hooked up correctly. I was hoping someone who has done this swap may know where the problem lies.
Also on a side note. The throttle cable isn't long enough to fit like it is supposed to be I bent the retainer a bit but the gas pedal is very sinsitive and when shifting the engine will rev then slow down. (when taking my foot off the gas there is also a delay when the car actually realizes that.)
