when i cleaned my air filter the other day i noticed that there was oil in the filter and intake pipe. What could be causeing that?
oily air filter
It's normal to have a bit of oil in the intake system, but if its alot it is signs of excessive blow by.
02 Crv
Wouldn't bad piston ring's and valve seal's cause this to?this was put together by evil_demon_01 . You can also fined all this and more by him in the Common Beginner Technical Info can be found in here. PLEASE READ HERE FIRST
Car safety checks
Fluid Capacities
Yes which is blow by and engines this old will have it some alot worse than others i had a bit of blow by on my last build and it was healthy and produced no smoke at all, but still had more blow by than it should have.Originally posted by Accord problems View PostWouldn't bad piston ring's and valve seal's cause this to?
PCV is $3 and can cause similar issues aswell if you can't hear it rattle replace it.Last edited by SOHC-FTW; 02-02-2012, 12:22 PM.
02 Crv
I had this problem with my old f22a1 . My recent engine had very little. And now none.Originally posted by roketdemon02 View Postyea its not alot of oil but i do have a hose that goes from valve cover to the intake is a lil colapsedthis was put together by evil_demon_01 . You can also fined all this and more by him in the Common Beginner Technical Info can be found in here. PLEASE READ HERE FIRST
Car safety checks
Fluid Capacities
Replace it and the pcv. It might make a difference . unless your motor is to far gone.Originally posted by roketdemon02 View Postyea its not alot of oil but i do have a hose that goes from valve cover to the intake is a lil colapsed
Like bad piston rings , scars in the cylinder walls might be deep allowing oil to get bye.this was put together by evil_demon_01 . You can also fined all this and more by him in the Common Beginner Technical Info can be found in here. PLEASE READ HERE FIRST
Car safety checks
Fluid Capacities
Where do you put the oil catch can?Originally posted by WhiteShift View Postbuy a oil catch can, this will give you a lot of help for eliminate return oil
Car safety checks
Fluid Capacities
That would be mighty nice.Originally posted by dhill_cb7 View PostAble to supply a picture of the hose? If it is collapsed then maybe it is time to replace the hose?this was put together by evil_demon_01 . You can also fined all this and more by him in the Common Beginner Technical Info can be found in here. PLEASE READ HERE FIRST
Car safety checks
Fluid Capacities
