What exactly was it? I ask so I can point noobs to this thread . To get at least an idea.
Burning coolent through my exhause
this was put together by evil_demon_01 . You can also fined all this and more by him in the Common Beginner Technical Info can be found in here. PLEASE READ HERE FIRST
Car safety checks
Fluid Capacities
My bad! The leaks were minuet, quit spray, I guess with the heat it would evaporate more than leak. My U hose behind the intake needed to retightened and clean up form that gunk build up, abit of sand paper and wire brush did the job for a snug fit. I pump my pressure up to 17psi again, and shook, pulled and tug on some more hoses, my upper hose needed the clamp replace, I detect a loss of pressure 16.5 psi and the housing that come out the head cylinder need to be clean out as well (wire brush), I did put a light coating of water pump sealant in that housing. Pump it up at 17psi had lunch and return in and hour and holding steady for at 17psi. I ran my car for two days before I returned the pressure kit rental, pump it up again to 17psi, took a two hour nappy with my four year old daughter, and viooooola! My system is holding 17psi. Done deal and enjoyed a victory smoke.
This was my first time using a coolant pressure kit, easy to use and worth my money and lastly very affective. I would of called mission accomplished when I found my U hose leaking, but I made a best effort to test my entire system and found other weak links in the chain. Hope this helps?
Good stuff man. Thanks for posting your fix.this was put together by evil_demon_01 . You can also fined all this and more by him in the Common Beginner Technical Info can be found in here. PLEASE READ HERE FIRST
Car safety checks
Fluid Capacities
