Okay, i have a very strange problem with my F22A1 these day's......The engine stall after 1 hours of Driving. The RPM is floatting Up/Down when i was driving on the Ville-Marie Highway,not alot of power on the pedal gas but I just have time to take the Exit and park the car. No check engine at all.
Do you think it's the Fuel Pump ? or the Ignition Coil ? ... So i spent couple of dollar's on a New Battery, New Connector,New 4 guage Ground,New Ignitor Module,New Cap Dist.,New Rotor,New NGK Spark Plugs Wires,New NGK Spark Plugs,New Fuel Filter,New Radiator with Prestone(Bleed the system),New Oil Change(ENEOS(nippon) Synthetic GF-5 oil),New Honda Oil Filter.
Run the car for 5 or 6 hours, and again same problem , the RPM start to Float Up Down , lost of power on the pedal gas, low rpm and stall.......I listen to the Fuel Pump and yes the fuel pump Open. But the engine dont start, just Crank.
I try this morning after 24hours, and the engine start A1, firts crank, after one hours at the idle, the RPM start to drop down,rough idle and stall.....The engine just crank and dont Start... No check ENGINE!
There some parts that i didn't change on my CB7 ( FUEL PUMP, EXT. IGNITION COIL , O2 SENSOR)
HELP !
HELP !
