Picture of map sensor and hoses, h22a1 setup
    As the title says, does anyone have a picture they can upload of the map sensor and hoses connected to it and where they run in their h22a1 setup. Is it different or does it matter if the car was converted from automatic to manual. I have always noticed the car to be a little "jerky" at times, and always threw a cel the first time it occurs after start up. FINALLY got it checked today and it is the map sensor and throttle body codes. Any suggestions, I'm looking to fix this on my own. thanks
    Everyday is one day closer to completing my cb7 <3
      easiest thing to do is keep stock map(one from the cb7), just run a vaccum line to a port on intake mani, to the bottom of map in the black box. just another choice
        cpmike, i saw this picture in abother thread. however everything seems to be in check.
        danf20bcb7 now this vacume line that your talking about, how would i connect it to the map. i have no knowledge of these things at all
          bump
          please guys. I Have seen lots of threads online but nothing that seems to be the solution to my problem. My car is throwing a map sensor and throttle body sensor. I figure these systems are tied in together, so it might be one cause the other to go off, I could be wrong. When I am driving, and flooring it, the odd time the car will not want to go anywhere, it takes forever to generate power. I put it in neutral and rev'd it up and it was weak as hell. After pulling over to answer my phone, I went back on the road and the car was all good. I noticed it has been doing this slightly, but now its just ridiculous, and I would like to get it fixed. With the picture above, it seems everything on mine seems to be correct, unless my sensors are shot? I have no clue. I am using the stock map sensor for my h22a1 setup and the only thing I noticed that seems out of place is the that there are two nipples under the intake one pointing to the left (if you were standing in front and looking at the car) and one pointing to the front of the car. They have nothing connected to them.
            Post up a pic of yours. I just got done swapping mine a couple weeks back - I can post a pic for you tomorrow morning.
              These pictures are not exactly for the h22a1, they are for an f22ax, but it should get you setup properly.
              Here you go:
              <-- If this post is helpful, don't forget to rep (click the scale)
                Ok. so here are the pics of the setup i have
                the two nipples i mentioned earlier
                  you get those pics?
                    Originally posted by cp[mike] View Post
                    in this picture. The fourth arrow would be the one you connect to the intake? Correct?
                      No, #4 in that picture goes to the EGR valve. The air boost valve on the far side of the manifold goes to the intake.
                      Originally posted by Junior Smurff
                      Nevermind guys, google search works wonders!
                      I don't have road rage, my car just goes faster than yours!
                      Accords are for winners. And Grandmothers. But mostly winners.
                      I have grown so Tired of Internet Illiteracy. Please learn proper spelling and grammar. For your sake and that of your children.
                        ok. I see now. And mine is connected as follows. Which vaccume line do you suppose i should use on the intake manifold?
