i know its normal for it to come on when the car is off but thats the only time the cooling fan will come on, when the ignition is on the fan will not come on, but turn the key off then on comes the fan.... any suggestions
cooling fan comes on when car is off
My car does this but it turns on when it's on too, the fans come on when the car is off to cool the engine faster.1993 10th Anniversary MRT
Originally posted by The G-ManFor that money, yes. But my dick isn't big enough for that shit.
List of all my cars to date
No. Its only if the engine is over heated when you turn it off..Originally posted by Wickit View PostMy car does this but it turns on when it's on too, the fans come on when the car is off to cool the engine faster.
When you turn the car off the fan timer always sets the circuit on for 15minutes.
Its up to the sensor to turn the fans on or not depending on the temp of the coolant.
A properly running cb shouldn't have the fans come on unless its a super hot day.wat?
im pretty sure its called the "cooling fan switch" its should be around $25 at a parts storeOriginally posted by android_proball View PostI tried this. My fan does turn off when I unplug. ): so what is this sensor called? And is it the green/blue plastic, or the nipple that is bolted into the water neck?
