Thread Tools Rating: Thread Rating: 6 votes, 4.83 average. Display Modes
Old 08-16-2011, 12:39 AM   #1
Wickit
Wickit is cool... so far.
Wickit : 1993 Accord 10th Anniversary
My First Car, I'm 18 (when i started I was 15) and this my daily driver CB7, aka Jasmine. I planned on keeping it as a daily driver but now I have been inspired to do a full race build. I bought her for $1150 in "drivable" condition on August 5, 2011. She needed alot of work (i was told by my mechanic AFTER i bought it) but the seller said it just needed AC servicing. Will post progress and updates.
~1st day 8/5/11
~Early 2012
~More mods
~Late 2012
~Early 2013
~Mid 2013
~Current
Timeline:
08/13/11- Replaced leaking coolant hose & put on new battery clamps.
08/15/11- Put on LED license plate lights from eBay.
08/16/11- Installed Fram air filter.
08/28/11- Valve Cover Gasket Replaced.
08/30/11- Transmission Drain & Fill.
09/03/11- Tune up (Spark plugs and idle timing set).
09/04/11- Replaced Valve Cover Gasket (AGAIN).
09/13/11- New Valve Cover (Painted Lime green).
09/20/11- New PCV Valve grommets for both covers.
09/24/11- New Distributor cap, rotor, and ignition wires.
10/11/11- New Radiator installed.
10/13/11- New Amber LED corner lights
10/27/11- New By-Pass hose installed.
10/28/11- New Fuel Filter installed.
10/28/11- New blacked out dome light lens.
10/31/11- New black housed Clear corners installed
11/05/11- Painted OEM grille matte black w/ tinted Honda emblem.
11/11/11- Super White LED Dome light & New Trunk light w/ cover installed.
12/03/11- New courtesy lights installed
12/17/11- Ash Tray Installed.
12/22/11- Honda License Plate put on.
01/19/12- Sides & Front motor mounts & K&N cone filter installed.
02/08/12- Passenger side Axel replaced.
02/10/12- Driver side axel replaced.
02/11/12- Rear Motor mount installed.
02/14/12- Passenger side axel replaced AGIAN with correct axel this time.
02/17/12- Legend sedan lip & window visors installed.
02/18/12- APC Muffler installed.
02/22/12- Hood painted black.
03/13/12- Installed rear left speaker.
03/14/12- Installed rear right speaker.
03/15/12- Installed Ignition killswitch.
03/29/12- Painted OEM 6 Spoke Alloy wheels white.
04/08/12- Replaced hose clamp on lower radiator tube, stopped the leak.
04/10/12- Installed Broadway Mirror.
05/06/12- Replaced both drive belts.
05/12/12- Installed coilover sleeves.
05/18/12- Installed Wink Mirror
05/27/12- Konig B.Bombs mounted on.
05/28/12- Replaced brake light bulb.
05/29/12- Hit 276k miles
06/06/12- Installed Black housed headlights w/ yellow high beams.
06/20/12- Installed 16 LED Dome light & Super white Trunk light.
06/26/12- Installed 8 LED Corner lights.
06/30/12- 2.25" Straight Pipe Installed.
07/18/12- ViS Carbon Fiber hood installed with hood pins.
07/25/12- OEM Valve Cover Gasket & spark plug seals 1 & 3 replaced.
07/28/12- OEM Spark Plug seals 2 & 4 replaced, NGK Spark Plugs installed.
07/30/12- Timing belt, balance shaft belt, water pump & front passenger lower ball joint installed.
08/07/12- Oil changed, tires rotated, fluids checked.
08/07/12- Quick release, Hub & Steering wheel installed.
08/08/12- Added CD5 rear lip.
08/09/12- Did a leak down & conpression test (10% & 210)
08/10/12- Adjusted front legend lip to fix sagging.
09/10/12- NRG Quick Release Set Up Installed.
10/10/12- New speakers (JVC & Pioneer)
10/11/12- Tint taken off except for back window.
10/30/12- Rack & Pinion installed and Megan Racing muffler installed.
10/31/12- Aligned using measuring tape.
11/01/12- Replaced wheel stud.
11/06/12- Added locks to hood pins and put F22 Japanese plate in windshield.
11/11/12- JDM CS-X3 Air Spencer Added
11/16/12- OEM Accord Bottlecaps with mismatch tires installed.
11/17/12- Both drive belts replaced, again.
11/30/12- BSA 220 Wheels installed with low pro tires & locking lugs.
12/12/12- U<3MYCB7 Plates installed
12/17/12- 92/93 Black Mesh grille installed
12/17/12- Oil Change w/ filter.
12/18/12- Installed No Name Front Upper Strut Tower Bar
12/21/12- Replaced Passenger Healight Bulb.
12/12/12- OEM Honda Seals, Belts, Water Pump, and Valve adjustment
12/25/12- StanceNation Plate Frames Added (Front and Back)
12/25/12- GPS Navigation System Added
12/29/12- Red Clear Tails installed
01/09/13- Fixed Driver Rear door not engaging dome & door light.
01/20/13- New wheels installed, Koya GTR
01/24/13- Fenders Rolled & replaced tire with camber wear.
02/02/13- Front Brake pads, rotors & wheel bearings replaced
02/19/13- Replaced transmission cooler line.
02/28/13- Prelude Sawblades installed.
03/09/13- Installed LED 19 SMD Reverse Lights
03/23/13- CF1 Carbon Fiber Trunk Installed
03/27/13- Honda of America Emblem installed on grill
04/06/13- Quality used tires installed on Borbet Reps and installed on car.
06/27/13- Greddy Evo2 Muffler Installed
07/11/13- HID Kit Installed 6k Low beams
07/23/13- Viper Alarm Installed
08/04/13- Black 14" Fanblade rims installed
08/22/13- Volk Racing CV Pro rims with Bridgestone Tires installed.
09/06/13- Pioneer Stereo Deck installed
09/12/13- Smog Test for registration, passed.
09/20/13- Tags for 2014 received.
10/14/13- Mudflaps Painted Pink (for breast cancer awareness.)
11/18/13- Swaps started
SPECS:
(Yellow = UNINSTALLED/NOT IN USE)
(Green = CURRENTLY INSTALLED/USING)
ENGINE / EXHAUST:
~PRE-SWAP SET-UP~
- USDM F22A1 Engine
- Automatic F22 Transmission
- Roughly 350k miles
- 2.25" Cat back Straight pipe into a Greddy Evo2 Muffler
- K&N cone filter on stock pipe
- NGK V-Power Spark plugs
- Lime Green Valve Cover
Replaced:
- Honda Timing & Balance belt
- Honda Water Pump
- Anchor Motor Mounts
- Anchor By-Pass hose
- BOSCH Dizzy Cap
- AC Delco Ignition Wires
- KEM Dizzy Rotor
- Lynol Radiator
- Tranny Cooler Line
- MANN Fuel Filter
- Honda Drive Belts
- Honda VC gasket
- Honda Spark Plug Tube Seals (Upper & Lower)
- Honda Cam, Crank & Balancer Shaft Seals
~Swap~
- H22a4 with Euro R Head
- 5 Speed swapped (H22 LSD tranny)
- AEM CARB Legal Intake
- Wire Tuck
- Battery Relocation
- ABS/CC/AC/PS Delete
- 2.25" Cat back straight pipe with Greddy Evo2 Muffler (for now)
- NGK V-Power Spark Plugs
WHEELS / SUSPENSION:
- Volk Racing CV Pro 16x7 +38 w/ Bridgestone Playz 205/55/16
- Rolled Rear Fenders
- AJP Coilover Sleeves
- No Name Front & Rear Upper Strut Bars
- Tein Super Street Coilovers Fully Adjustable
- Ingalls Front Camber Kit
Replaced:
- Cardone Driver & Passenger Axels
- Cardone Rack & Pinion (Replaced twice)
- Beck/Arnley FR lower ball joint
- Master Pro Outer Tie Rods
EXTERIOR:
- Faded OEM Arcadia Green Pearl Paint
- Front & Rear mud guards
- Legend Sedan Lip
- CD5 Rear lip
- Window Visors
- ViS Racing Carbon Fiber Hood w/ Red pins & locks
- LED bulbs
- Black Housed headlights w/ yellow high beams
- 6K HID Low Beams
- Amber Corners with reflectors
- 92/93 Mesh Style Grille w/ HOA Emblem
- 92/93 Red Clear Taillights
- 92/93 CF1 Carbon Fiber Trunk
- StanceNation "Fresh as f*ck" Plate Frames
- Custom Plates (U<3MYCB7)
- Pink Mudflaps
- JDM 1 Piece Headlights Black Housed and Yellow High Beams
- HC1 Accord Front Lip
INTERIOR:
- LED Lights
- OEM Tan floor mats
- OEM Tan Leather Panels
- NRG Quick Release, Short Hub & Steering Wheel
- DA9 Integra Headrest
- Wink Mirror
ELECTRONICS:
- 2 JVC Rear Speakers
- 2 Pioneer Door Speakers
- Pioneer Stereo Deck w/ remote and detachable face
- Viper Alarm System
- Ignition Killswitch
FUTURE PLANS
Short Term Plans:
- Fortune Auto Coilovers or Ground Control & Koni Yellows
- Splitter
- Energy Suspension Master Bushing Set
- Progress Rear Sway Bar
- 3 Point Strut Tower Bar
- Rear Camber Kit
Long Term Plans:
- Function Form LCA's (Gold)
- Beaks Rear Tie Bar (Polished)
- Bride Racing Seats
- REPAINT
- Engine Dampeners
- "Stage 3" Clutch & lightweight Flywheel
- Port & Polish
- OBX ITB's
- Upgraded Brakes
1993 10th Anniversary MRT
Originally Posted by The G-Man View Post
For that money, yes. But my dick isn't big enough for that shit.
List of all my cars to date
Wickit is offline   Reply With Quote
Old 08-16-2011, 12:49 AM   #2
SOHC-FTW
SOHC-FTW seems to have made some friends!
NiceGood platform to start with man.
02 Crv
SOHC-FTW is offline   Reply With Quote
Old 08-16-2011, 01:10 AM   #3
Tippey764
Silver Member
Not to common to see 10th AE's
Hows the ABS? Does it still work?
Also those floor mats are not OEM.
Tippey764 is offline   Reply With Quote
Old 08-16-2011, 02:40 AM   #4
Wickit
The abs works great and idk about the mats I'm just going from what the guy told me. I have some maroon ones in the back as well.
Old 08-16-2011, 02:46 AM   #5
Tippey764
Silver Member
Naaa they aren't OEM
OEM black floor mats are a bitch to find
Here are some OEM black floor mats
They say accord on them
Having a tan interior you can easily upgrade to a tan leather interior ( the most common color for OEM leather in north america )
You could also pick up some of these nice SE mats
Old 08-16-2011, 03:04 AM   #6
Ander
Ander is cool... so far.
Send a message via AIM to Ander Send a message via MSN to Ander
No engine bay pics?
Member's Ride Thread
Originally Posted by mercyboy View Post
I'd rather lose by a mile because I built my own car then win by an inch because someone else built it for me..your car is your story, so don't let someone else write the book!
Ander is offline   Reply With Quote
Old 08-16-2011, 03:17 AM   #7
Wickit
Originally Posted by Ander View Post
No engine bay pics?
I keep forgetting!! Haha I was suppose to take some yesterday but I forgot. Also are those tan ones yours??? The se one's
Old 08-16-2011, 10:37 PM   #8
Wickit
Some engine pics:
Old 08-16-2011, 11:31 PM   #9
93SM4_CB7
93SM4_CB7 is cool... so far.
Send a message via AIM to 93SM4_CB7
Nice platform to start with bro
Dude keep the green. I get compliments on my 10thann's green paint all the time.
Just some tlc and youll be golden.
Check Out My Work In Progess . . . . .
93SM4_CB7 is offline   Reply With Quote
Old 08-16-2011, 11:47 PM   #10
Wickit
Really? Haha idk cuz im not sure on how to get the like sun cancer crap and the driver door is starting to rust at the top. And all 4 doors look like a different green than the oem Arcadia Green. So I was gonna paint it like a Sonic Blue Pearl or the OEM Black for 10th Ann's. Haha so would I need just to have someone do like a touch up or would I need a new arcadia green paint job?
Old 08-16-2011, 11:49 PM   #11
Ralphie
Stalker
Ralphie is damn fine. Damn fine, indeed. Ralphie is damn fine. Damn fine, indeed. Ralphie is damn fine. Damn fine, indeed. Ralphie is damn fine. Damn fine, indeed. Ralphie is damn fine. Damn fine, indeed. Ralphie is damn fine. Damn fine, indeed.
Nice, i see you decided on a format for your MRT!
Good stuff, told you it is nice when its short and sweet!!
Oh and nice cb btw!!
Ralphie is offline   Reply With Quote
Old 08-16-2011, 11:56 PM   #12
SPLCB7
SPLCB7 is cool... so far.
Send a message via Yahoo to SPLCB7
Nice start
My 90 coupe Mr thread....
SPLCB7 is offline   Reply With Quote
Old 08-17-2011, 02:12 AM   #13
Wickit
Originally Posted by SPLCB7 View Post
Nice start
Thanks guys! And yeah I like this format :P
Old 08-17-2011, 07:57 PM   #14
Daheavyking
Daheavyking is cool... so far.
Send a message via AIM to Daheavyking
Man, 10th anns are popping up more often now. Nice cb man. Keep it clean
My coupe!!!
Originally Posted by Racer_XXX View Post
Daheavyking is offline   Reply With Quote
Old 08-18-2011, 03:03 PM   #15
Wickit
Thanks and i definately will.
I noticed that my engne had a coolant leak and i just fixed that and bought some battery clamps and now i need to see about my antenna today. Also gonna see how much its gonna be to repaint the entire car in the Stock Arcadia Green color but i was thinking about maybe havng the entire thing the OEM Granada Black and have the interior reupholstered black cloth or maybe leather. Thoughts???
Old 08-19-2011, 01:34 AM   #16
Wickit
Thinking about painting the wheels soon!!! Should I go Black or Gray and Polish or like a powder white?
Old 08-19-2011, 08:36 PM   #17
Julio@Bisimoto
Julio@Bisimoto is cool... so far.
good price you got it for bro looks like the beginning of a fun and addicting project
Julio@Bisimoto is offline   Reply With Quote
Old 08-20-2011, 12:35 PM   #18
Wickit
haha i know, and yes. VERY addicting but it is fun(: haha i just need job. Instead of sometimes getting a little money from craigslist jobs. lol I hate being 15! Stupid "insurance policies" LMAO its gonna be a slow build for now.
Old 08-20-2011, 02:13 PM   #19
Ander
Read through the DIY section. I bought my car when I was your age without much money.
The DIY section has alllllll sorts of fun, cheap, effective mods.
Old 08-20-2011, 02:24 PM   #20
SPLCB7
Very true....junk yards are awsome two at 15 i spent lots of time going through them when i was your age....heck i still do lol....and you can find rims sterio systems ect ect if you hit them up frequantly.....you have to get to the cars when they first get in thats when you get the good stuff....thats why i say go an lot
