Im just curious if sludge in the sump and the oil pick-up would cause low oil pressure only when hot. Im using 5w30 and some oil treatment so it should be about 10w40, but I get about 8psi at idle when "HOT" when its cold or when I raise the rpms the oil pressure is really good. Would sludge in the sump and oil pick-up cause that or is it bearings. It is a f22a1 with 173,000 miles.
Sludge
Sludge itself could cause a problem if bad enough.
Are you sure there is actually a problem though? - http://www.cb7tuner.com/vbb/showthread.php?t=186323
My 5.7 LS1 Holden Ute
the manual says I should be getting 10 psi at idle at a minimum with 5w30 oil im using 10w40 so I would think it should be higher. I was getting the oil to come on at idle as well. I just thinking of easy things to check. I do have a dent right in the sump on the pan could it be close to the pump?1991 Honda Accord 2DR LX 180,000 Miles RIP
ok thanks that the kind of answer iv been looking for. It does tick at idle, but all these cars do.
One other thing is this morning it was about 2 degrees Fahrenheit and it took about 2 seconds to build oil pressure and it ticked but then the sound went away, I know that is because im using a thicker oil, but could it have cause a lot of damage. It felt like forever lol.1991 Honda Accord 2DR LX 180,000 Miles RIP
