What has coolant going to it on the drivers side?
    Anything over there besides the water pump?
    Anything that isn't the water pump? Please?
    MRT
    sneaky motherfucker
    water pipe is there which leads to the water pump, some heater core hoses are on that side too, maybe those are more near the center if i recall.
    '94 CD5 EX F22B1 Automatic
      Hard pipe on the back of the block is all i can recall.
      02 Crv
        I haven't had a chance to peak up under there, but it looks like it's coming more from the front. Actually, it drips off the oil pan/timing belt cover it seems.
        I'm hoping it's the rad. My timing belt isn't due for another 40k miles and I don't want to do it right now.
        Side note: When I park, it drips to about a 6 inch diameter spot, then stops.
        I'm pretty sure it's coolant. It tasted sweet but bitter.
        MRT
        sneaky motherfucker
          Very good possibility it's the water pump. Take the upper timing belt cover off and see if you can find the leak or any wet spots.
          02 Crv
            if you have some car ramps or even better a lift you should check to see if the water pipe is leaking from A. Rusting through B. An oring that has been worn out or C. Those hoses that im referring to as heater core hoses leaking.
            id do that 1st because its easy lol
              Water pump.
              Back of pump oring to pipe, oil cooler.
              wat?
                Damn. I don't really want to do that, especially this time of year.
                I've always been against stop leak, but I might actually use some to get me to the summer, depending on where it's leaking from
                One last question: I recently fixed my upper rad hose and added just generic brand coolant to make up the difference. Would that cause leaking?
                MRT
                sneaky motherfucker
                  Highly doubtful that your new coolant would case a leak, unless it was really straight acid instead of coolant.
                  I actually just got O-rings for my water pump intake pipe yesterday, sort of a pain to find. Everyone online wanted $2 for them but $15 in shipping. I ended up finding them at a honda dealer for $3 each... just some FYI since I could not find them at any autoparts store. Also the job to fix them is not that tough either.
                  However if it looks like it is coming out of the front, you can almost rule out the pipe leaking.
                  "There is nothing wrong with you that an expensive operation cannot prolong."
