Go to the Honda's website, select that you want to buy parts. Then you can select the nearest Honda's dealer to you. Pick the parts you want, pay for it, then pick them up from your dealer. The gasket is just about $11. The spark plugs upper rubbers seals are like $4 each.
valve cover gasket recommendations
i recently replaced my buddy's VC gasket on his D16 and yes i put on some sealant in the cam humps and in the corners. I don't know if his gasket was ever replaced because on all four corners and on the cam hump it was just wet as hell from oil leaking. I did the job like two weeks ago and this past monday i checked on it just to make sure and sure enough it was dry.
Originally posted by Bad_dude View PostYou don't actually need the humps dabs but just in case the valve cover is scratched. It's just a precaution. Nothing worse then just putting on a valve and find a tiny leak a week later. Go with OEM gasket as the cost is not much more.
Originally posted by Leung View Postactually i think the Honda one is cheaper because my buddy paid 17 dollars for the Felpro one at Pepboys but it also came with with upper tube seals and rubber grommets for the studs.10th Anniversary Accord.
05 Audi A4 Ultra Sport 6MT.
