So I've narrowed down the problems that my car might have. Its either a bad distributor that is causing my car to turn off while driving, or the fuel pump. To my knowledge, thats all iknow at the moment. I checked bing and searched a bit on the forums but couldnt find a thread containing info on how to test your distributor, and bing seemed didnt have much info on there. So is there a way to test the distributor? and the fuel pump?
How to test Distributor and fuel pump?
Originally posted by Eazymartin View PostIt doesnt bog, it would just turn off, it has turned off on the freeway going 70pmh, The CL came on when it turned off.98' Mustang 3V Swap
11' VW CC R36
Sounds like we have the same problem.
http://www.cb7tuner.com/vbb/showthread.php?t=184889
I ended up replacing the distributor, and with it the crank sensor.MRT
Originally posted by Tippey764I think driving your car naked will cause the engine to overheatOriginally posted by deevergotesneaky motherfucker
