Where is the starter located?
    Where is the starter at? My car wouldnt crank, it isnt the battery. I want to go get my starter tested but i dont know where. I saw that it is on top of the transmission....i dont know where that is either. Please help.
    My Baby "CLEO", Slowly Making Her Mine
    ok what motor do you have? also any parts store should be able to test starters. does it attempt to turn over at all (clicking)?
      i dont hear any clicking from inside the car, but ill turn the key all the way to start and the dash lights will come on, headlights do not dim, and i hear some sort of whining noise.( not the wur wur wur wur ) as if it were trying to turn over just a high pitched whining noise.
        Starter is located on the top of the transmission. If its auto itll be on top. If manual it will be near the front top side of trans.
        COUPE K24
          the whining noise might be the fuel pump sometimes you can hear them prime. you would be able to hear the click of a starter its quite noticable.
            If you can't locate the transmission then maybe you should just take your car to a professional. the transmission is attached to the left side of the engine
              Right under the spark plug wires in this pic.
              MRT
              sneaky motherfucker
                Left side of the engine. Under the spark plugs, to the right of the lower rad tube.
                The 2.5 inch in diameter circle thing.
                MRT
                sneaky motherfucker
