ive seen the thread under the suspension topic and it wont let me post a reply, so im asking here. Will an eg (92-95) civic front camber kit work on our cb7? they look like they are the same control arm shape but i dont know for sure. i bought the adjustable things on ebay but they are garbage so this is why i want to know.
Front Camber Kit
if u want that mad camber hellaflush look they will fit but there not as long as cb uca so even fully extended youll have some mean camber
http://www.cb7tuner.com/vbb/showthread.php?t=187851
sold to: cb7rush\h22-accord\Luis\BurtonRiderT6
bought from:jokerxfn-tommi-'93cb7ex
Absolutely not. Those EG or EK or whatever control arms will give you major negative camber, even with camber kit installed. Like dude said, people use them when they are going for that hellaflush look. Whatever you bought on Ebay may have been garbage, thats why you buy a reputable brand. Buy the kit made for a CB, anchor bolt or sliding ball joint style whatever you prefer.Originally posted by 700hpCb7 View Postso it wont make the camber perfect to no tire ware?
Second the SPC upper adjustable ball joint kit. I got it from summitracing.com I've been driving hard with it installed for the last 2 years with no issues at all and no slippage.
FYI you can run up to -1.0 camber in front without wearing your tire out prematurely, granted the toe is kept in spec. I've had mine at -0.9 for about 15k miles and I can BARELY tell a difference in tread height between the inside and outside.....with high performance A/S tires that I expect no more than 40k from this is no issue for me because I like the better handling that comes with a little negative camber.My Member's Ride Thread
