got a question i blew the motor in my 90 accord f22 a1 knocked a couple holes in the block..needless to say its shot so i came up on a f22b1 wen i was lookin for another motor for 300 buck was just wonderin bout if i should put the a1 head on it with the h23 intake i already had or just swap the motors out i got the wiring and everything else down i think just not sure bout wat the wires are comin from the crank think its pressure switch for the vtec.....if so i was gonna put the h23 mani on the f22b1 just wanted to get a couple of opinions on wat u guys thought on which would be my best bet...and was also wonderin if my header off the a1 would fit the b1 it didnt come with one on it havent got to checkin it yet and i kno i need the p0a ecu for the b1 right?
f22 a vs f22b1
The b1's Ports are different from the a1's. The only way he can reuse his header is if he adds the a1 head to the b1 block.Originally posted by Joey GT-R View PostThis is really a matter of opinion. You could go either way. The cylinder ports are identical so your header will fit.Originally posted by Mishakol129Do not disrespect my intelligence. I am the smartest person I know : )
Yes. B1 exhaust ports are 0_00_0. F22A, H23A, and F22B DOHC exhaust ports are 0_0_0_0.
You can put the F22A head on the F22B1 block. The blocks are very similar. The F22A head has greater potential when modified, compared to the F22B1... but both are decent motors until you get REALLY serious about a build.
Keep your F22A head if you want to avoid having to replacing your intake & exhaust manifold. Nether of the ones you have will bolt up.
Another thing to remember if you end up swapping blocks. Remember to remove the oil control orifice from your blown F22A block and screw it into the B1 block. The B1 VTEC block does not have the control orifice becuase the B1 head requires more oil to engage the VTEC assembly.
Originally posted by GhostAccord View PostKeep your F22A head if you want to avoid having to replacing your intake & exhaust manifold. Nether of the ones you have will bolt up.
Another thing to remember if you end up swapping blocks. Remember to remove the oil control orifice from your blown F22A block and put it into the B1 block. The B1 VTEC block does not use the control orifice becuase the B1 head requires more oil to engage the VTEC assembly.
Thanks for that bit of info. Im working on a CD5 right now and when I popped the head off I noticed that plug was missing and was curious about it.
Guess you learn something new everyday....wonder why they did that. When you look at headers online they always advertise F22/H23, but I've never seen them say "except F22B1". So I guess it's safe to say H22 headers, manifolds fit then?Originally posted by deevergote View PostYes. B1 exhaust ports are 0_00_0. F22A, H23A, and F22B DOHC exhaust ports are 0_0_0_0.'94 JDM H22A: 178whp 146wtq
Originally posted by deevergoteIf you say double dutch rudder, i'm banning you...
