dash water leaks
    dash water leaks
    Hi i just recently bought a 1990 ex that runs and drives fine it just has two water leaks both under the dash one near the driver side door and one near the passenger side door.it doesn't happen if i'm driving just when the car is sitting in the rain.Any idea's?
    poor insulation on the windsheild? water is seeping through the seal. rust or hole somewhere allowing water to spread. i would more assume something big because it is on both sides. good luck.
    Everyday is one day closer to completing my cb7 <3
      It's an ex, so it has a moonroof right? Every moonroof has drain tubes on each corner. They run down inside the a-pillars and exit out the sides of the cowl. They can become clogged easily causing the water to backup and drain into the car. Sometimes you can use an airhose and blow air down the tubes. If you open the moonroof you can see the front drain holes pretty easy. Good luck
      http://www.cb7tuner.com/vbb/showthre...=1#post1823428
      My Custom BB6 Dash Swap Thread
        didn't work, ha just my luck. thanks for the suggestion tho.
