What Are The Goods And Bads And Is This A Good Engine?
F22A1 Goods And Bads.
Good. You found the proper place to post this. Now please delete the thread in the appearance section.
The F22A engines are all the same, other than what is bolted to them. The F22A1 is the weakest of the 3 (F22A1, F22A4, and F22A6) making 125hp. The F22A4 makes 5hp more with the only difference being the exhaust manifold. The F22A6 makes 140hp with a different exhaust manifold, intake manifold, camshaft, valve springs, ECU, and a windage tray in the oil pan.
Most of the differences are parts that get replaced when the engines are modified anyway, so any F22A is just fine to start basic mods with.
The F22A head, when modified (port and polish) can flow VERY well... it will outflow some of Honda's best heads. This only matters in a very serious, very expensive build, though.
The bad side is that the compression is quite low. Low compression ratios are good for turbo, but turbo on a stock block will break your pistons, as they aren't made for turbo.
When I responded, you hadn't yet.
1) It's VTEC, not Vtech. And no, the F22B1 sucks. That thing I said about the F22A head is the exact opposite for the F22B1. It's a terrible performance engine. Reliable and efficient, but no good for serious performance. It's only worth building if you have a 94-97 Accord that already came with one.
Look up how VTEC works (howstuffworks.com explains it well. Once you understand VTEC, understand that the SOHC VTEC engines have VTEC on the intake side ONLY. Understand it, and you'll see why that isn't a great thing for performance.
Read the "sticky" threads in the Swaps section of this site to see more engines that are good.
2) No stock Honda engine is "good with turbo". Anyone that tells you that knows less than you do (or at least they know less than you will by the end of today.)
In terms of low compression, just about any SOHC F series engine is "good"... but you will break a ringland very quickly with a stock-block turbo setup, no matter how carefully you do everything else. If it's a project engine that you don't mind blowing up, fine. If it's your daily driver, don't do it.
If you want reliable turbo, do your research, spend the money for quality parts, and build an F22A. It's the cheapest route.
3) Turn caps lock off. You're clearly trying to draw attention to yourself, and you're drawing the WRONG kind of attention.
isn't the pt6 better than the p12?this was put together by evil_demon_01 . You can also fined all this and more by him in the Common Beginner Technical Info can be found in here. PLEASE READ HERE FIRST
Car safety checks
Fluid Capacities
Ok thanks for the info.Originally posted by deevergote View PostFor an F22A1 in stock form? No.
Add an F22A6 camshaft and intake manifold (or H23A manifold), then yes, the PT6 is better. The PT6 is tuned for the A6 cam profile, and it operates the IAB system found in the A6 intake manifold (as well as the H23 intake manifold.)this was put together by evil_demon_01 . You can also fined all this and more by him in the Common Beginner Technical Info can be found in here. PLEASE READ HERE FIRST
Car safety checks
Fluid Capacities
