I've searched and searched and can only find one that isnt very thorough. can anyone help me out? What both size? how it works? and that kinda stuff? THanks!
Rear camber DIY.
Significance
When a car's body is lowered or raised, or its tire size is changed, the tires can tilt inward or outward instead of sitting perpendicular to the road as they are supposed to. This tilt is called camber, and can cause tire wear uneven alignment and eventual breakdown of your rear suspension.
Function
A rear camber kit is a special kit that is applied to a car's rear suspension after it has been modified. The kit fixes the tilt of a car's rear wheels and sets them back to their proper alignment. Each kit is created specifically for certain car models, as many cars have different types of suspension.
Considerations
When you are shopping for a rear camber kit, you should be sure that the kit is for your specific model of car, and is of high quality. This is because the rear camber kit's installation requires it to become a part of your suspension, and if it fails, it could ruin your rear suspension and cause your rear end to fall.
Rear washer trick: http://www.cb7tuner.com/vbb/showthread.php?t=56281
My 5.7 LS1 Holden Ute
