i have a manual trans and i was wondering where i can check the trans fluid at to see if i filled it too much...thanks
checking trans fluid?
You should really purchase a Hayne's manual at the very least and know your capacities when changing fluids. If you're tight on money search this forum in the COMMON STICKIES, they're there for a reason!!
Here's an online service manual link
http://www.cb7tuner.com/vbb/showthread.php?t=140314
And here is the fluid capacities for your vehicle.
http://www.cb7tuner.com/vbb/showpost...50&postcount=1
LOL, what "sais" to fill it up?Originally posted by brand0n327 View Posti know its 2qts .but it also sais to go til it fills up..and that was almost 3 qts...its been leaking for a day now and i want to make sure its not the seals
Vehicle capacities are given for a reason. You put 50% more than the capacity that is called for. Might as well stick 6 quarts of motor oil in on your next oil change.
If I remember correctly, there is a fill plug that is in the side of the transmission so that you cannot overfill it. I can't verify as I am currently at work but you could by clicking the link I gave you and downloading the proper service manual.
I really wouldn't go over the recommended amount, oil or tranny fluid. You're just asking for problems.Originally posted by brand0n327 View Postit wouldnt let me download it. and ive seen it on here when i searched. and honda tech. and it took over 5 qts of oil to fil my engine up. no balance shafts .so please dont be an ass when im asking a simple question.thanks-Ian
'92 EX Coupe (Member's Ride Thread)
My Blog - Mostly snark about professional motorsports, but I occasionally make it to local and regional events. It's not much now, but I'm working on it.
Your statement contradicts itself.Originally posted by BurtonRiderT6 View PostVehicle capacities are given for a reason. You put 50% more than the capacity that is called for. Might as well stick 6 quarts of motor oil in on your next oil change.
He is only asking if he overfilled the Trans.
OP - Fill it till it comes out the fill hole, that is how much it needs.
My 5.7 LS1 Holden Ute
It will come out the fill plug hole.Originally posted by brand0n327 View Postokay thanks. and will it push out if its too full? because it looks like its pushing out by the speed sensor, all bots are tight though
Do you know where the fill hole is? The 17mm bolt on the side of the diff housing.
I'm not contradicting myself, it's impossible to overfill the tranny if you use the proper method i.e. fill hole. He has no clue where it is so he obviously didn't bother opening a manual and went based off what "someone" said.Originally posted by evil_demon_01 View PostYour statement contradicts itself.
And to the me being an ass comment, buy a manual so you don't screw up your flippin car.
No balance shafts means add more oil? You have less rotating mass, there's no reason to increase the amount of motor oil you put in. Honda did the engineering and set the recommended amount for a reason.Originally posted by brand0n327 View Postit wouldnt let me download it. and ive seen it on here when i searched. and honda tech. and it took over 5 qts of oil to fil my engine up. no balance shafts .so please dont be an ass when im asking a simple question.thanks
