Passenger power lock problem
    Ok so I've searched a few pages. But no help. And I was wondering if the passenger side has a little box for the power locks like the driver side. When I hit my lock switch from the driver side I can only hear the front and back driver side lock. But the passenger side doesn't do anything and doesn't click. Any help would be appreciated
    I'm unsure about a black box as I have yet to tear into the door panels but have you checked all fuses?
      Heres the electrical diagram for the power door locks.
      If you need more wiring diagrams for any reason, check out this thread: [INFO] Chassis Electrical System - Typical Wiring Diagram Scans
      EDIT: There seems to be only 1 actuator for the driver side front, that should control the rest of the locks. I would suggest getting out a test light, and see if your getting power to the motors on the passenger side. If you are then the motors are likely dead for whatever reason.
        Ok thanks. Check up on it when I get some time later.
          It might be the attenuator. That can happens. Before this happens this your lock makes that whining sound but the lock does not go down? Any sound when hitting the lock switch?
            Just my input... But to my knowledge there is only one which is located in the driver door. Ive torn into three coupes before, never saw one in the passenger side of any of them.
            Everyday is one day closer to completing my cb7 <3
              Hey,
              I can't help on this one b/c I helped my friend replaced one but it was a 91 sedan and if I remember correctly, we bought a used attenuator from Ebay for the front passenger's side. It's been working since. Mine is making the pre-failure noise. Whenever I have all the doors lock except the driver's side. I press the lock switch to lock all doors, I get that short whine noise from the front passenger's side. Nothing in the rear.
