i keep having issues with front wheel bearings i keep replacing them and they keep going out i'm not really sure why any suggestions?
wheel bearings
Wow that's a bit more complicated to answer. How's your alignment? Are your shocks working properly? You running any negative camber? Are your axels banced? Are your motor mounts good? All these things play a role in the possibilities of why you are going through wheel bearings.
Purchased From: busak87, GunRunner, Bruce Banner, Itstatcb7kid707, tJoods, DannyD
The Caravan 2015
MRT:http://www.cb7tuner.com/vbb/showthread.php?t=180919
Could possibly be your axle. If the axle was ever replaced and it happened to have been replaced with an aftermarket one, aftermarket ones sometimes seem to be slightly longer which doesn't allow everything to tighten as it should. You can tighten the axle nut all you want, but if the axle's just the slightest bit longer, it'll leave slack. Same reason my buddies 4 wheeler bearing kept going bad.98' Mustang 3V Swap
11' VW CC R36
solutions to that?? both sides of mine i can move both wheels and feel the slack in the bearings, and my steering wheel shakes like mad under braking, and i just put new pads n rotors on.Originally posted by Gotz Cb7 View PostCould possibly be your axle. If the axle was ever replaced and it happened to have been replaced with an aftermarket one, aftermarket ones sometimes seem to be slightly longer which doesn't allow everything to tighten as it should. You can tighten the axle nut all you want, but if the axle's just the slightest bit longer, it'll leave slack. Same reason my buddies 4 wheeler bearing kept going bad.
