wiring questions.
    wiring questions.
    i was going to put a obd1 h22a in the 92. but i heard i would have to wire in the vtec, knock sensor, and something else. bcuz the car didnt come vtec!.. would i have to wire all that in if i used the h22 harrnest and computer??
    You cant change the whole harness to the ecu as in The wire is not in the part of the harness that goes from the ecu to the engine harness so it even if you use the h22 harness it wont work. You need to add the wires to the plug in the back of the ecu and run them into the engine bay and hook them up to there sensors or what ever they control. Idk about the knock sensor but I think you do need to add it but I know you need the vtec solenoid wires up and the vtec oil pressure switch.
    I think this is the same for all obd1 pinouts
    Uploaded with ImageShack.us
    Green EX http://www.cb7tuner.com/vbb/showthread.php?t=176536
    93 SE http://www.cb7tuner.com/vbb/showthread.php?t=210486
      alright thanks.. i notice it said b16 and gsr.. is this for genral or just these motors?
        I think its the same for all obd1 honda ecus. I know 2 wires are different on the 94-95 accord but I think thats it.
          kk.. is the f22 harrnes the same as the h22 or should i by a new one
            I think you can use any one you want.
            if you use the h22 harness you will have add the wires to the shock tower plugs to the ecu
            if u use the f22 harness you will have to add the wires all the way.
              Disclaimer: I have never done this so I dont know how accurate this info is but if I had to do it this is how I would do it.
                what are shock tower plugs?? sorry im like a 1st grader when it comes to electrical things
                  Open your hood, Look on the shock towers. The engine harness meets the harness that goes to the ecu there.
                    There is a good DIY for the engine swap, I looked it over a few times. I haven't done it yet still looking forr a good OBDI H22
                      Exactly. Much of what thepowderblue has said (along with similar images) can be found in the "sticky" threads found in the Swaps section. This has been covered in extensive detail, honestly.
                      Nathen, good job helping this guy, though!
                        [QUOTE=deevergote;2990821]Exactly. Much of what thepowderblue has said (along with similar images) can be found in the "sticky" threads found in the Swaps section. This has been covered in extensive detail, honestly.
                        well my bad bro. it was late last night and i didnt feel like playin with the swaps section,
                          Oh, so you're just lazy. I get it.
                          Carry on, bro.
                            lazy. yu dont even know what i did yeasterday.....
                            so im lazy cuz it was 3 or 4 in the mornin asking a question about wiring to see if anyone was nice enuf to help me out, whitch their is. but if i WOULDA KNOWN I WOULD HAVE DEAL WITH A D BAG LIKE YU I WOULDA STAYED OFF
                              buh bye
                              MR Thread
                              GhostAccord 2.4L Blog
                              by Chappy, on Flickr
