i know this might be a stupid question, but whats the diffrence between obd1 and 2? but on the same motor type
obd1 or obd2
What about the resistor box or what ever that thing on the drivers shock tower, Isnt it for the obd1 injectors and the obd2 injectors dont need itOriginally posted by deevergote View PostComputer, injectors, distributor. Those are the things you need to change to convert from OBD2 to OBD1.
OBD isn't always an indicator of the injectors resistance.Originally posted by thepowderblue View PostWhat about the resistor box or what ever that thing on the drivers shock tower, Isnt it for the obd1 injectors and the obd2 injectors dont need it
The 96-97 OBD2 Accord injectors are also low impedance 240cc just like the 90-93 injectors.
In order to tell if your injectors need a resistor box. You measure the resistance.
2-3 Ohm = low impedance (peak and hold) require resistor
11-13 Ohm = high impedance (saturated) do not require resistor.
I showed you how to wire all that crap up and you want to stay obd1.Originally posted by MCNELLY View Post1! thread is to figure out HOW to wire vtec, knock sensor..
2! i trying to figure out what one is better, obd1 or obd2 h22a.. their damn near the same price but i was trying to figure whats all diffrent
There are tons of threads showing everything you need to do this swap in the swap section. Read up. It will only help you from asking stupid questions...
Watch out... he might call you some nasty names. He's too lazy to actually read the information he needs, even the stuff that was very kindly put in "sticky" form for his convenience since, oh, I don't know... 2003!Originally posted by thepowderblue View PostI showed you how to wire all that crap up and you want to stay obd1.
