iv replaced hoses, thermastat, got the fans working and she still runs hotter than normal. idk what the deal is everything looks good. can anyone help me identify this problem?
h22a running hot n stumped
When you say, "...got the fans working..." do you mean that the car ran without radiator fans for an extended period of time?
Have you bled the system?
Did you replace the water pump when you put the H22A in?My Members' Ride Thread - It's a marathon build, not a sprint. But keep me honest on the update frequency!
i drove the car for about a month with the fans not working but it was still kinda cold up here when they werent working nd idk understand "bled the system" iv never herd these terms before. nd the water pump i have not replaced i figured itd be good deevergote i couldnt tell you if i put it in right i just figured it went in one way lol.
I can barely understand what you are saying. Please use real words if you would like help fixing your car.
"bleeding the system" means getting all air out of the cooling system (to put it simply).
Be sure you installed the thermostat correctly.
If you drove the car with no cooling fans, even in cooler weather, you may have caused damage.
Check your oil to see if there's coolant in it (if it's milky, there is coolant in your oil.) Likewise, check for oil in your coolant.
when i first did the swap i noticed the gauges would jump everywhere temp gauge going cold to hot, mph gauge jumping 5-10 mph while driving, but then everything started leveling out so i though it was "normal" maybe its just electrical?idk. i would really like to resolve this problem as soon as possible cuz the last thing i need is my car breaking down at 110 degrese nd my daughter in my car
ok so i went out to my car nd was checking things out nd found a whole in my hose so i went and talked to my buddie nine duece and he said that could very well be the reason my car over heats. also, he said i have a coolent censor that needs attention that i can yank off any accord nd itl work(big plus) he also told me the reason my gauges were jumping was bc i have a bad ground somewhere so I am yet to seek that out.
If you really want some help around here, you might want to put some effort in what you write. Do you know what the Shift key does when you hold it down and type a letter? Do you realize that a sentence should have some form of punctuation at the end of it?Originally posted by H22znt View Postok so i went out to my car nd was checking things out nd found a whole in my hose so i went and talked to my buddie nine duece and he said that could very well be the reason my car over heats. also, he said i have a coolent censor that needs attention that i can yank off any accord nd itl work(big plus) he also told me the reason my gauges were jumping was bc i have a bad ground somewhere so I am yet to seek that out.
Here are some more tips:
nd = and
idk = I don't know
i = I
bc = because
Are you really that lazy to type out the entire word? It looks like a third grader wrote what I just quoted.
Also, when you type, if a little red line is under the word, it usually means it is spelled wrong. Try right-clicking and selecting the correct spelling.
Take the time to type what it is you want to know and you just might get better responses and help from people in the know.
If you can defipher your last post, I would be glad to help.
Originally posted by djcaz_aom View PostIf you really want some help around here, you might want to put some effort in what you write. Do you know what the Shift key does when you hold it down and type a letter? Do you realize that a sentence should have some form of punctuation at the end of it?
nd = and
idk = I don't know
i = I
bc = because
Lol@ripping him about his english/typing and then asking him to 'defipher' his post.Originally posted by wed3kim a douchebag to people and i don't even own a lambo. whats your point? we, douchbags, come in all sorts of shapes and colours.
Talk about a run on sentence.Originally posted by H22znt View Postok so i went out to my car nd was checking things out nd found a whole in my hose so i went and talked to my buddie nine duece and he said that could very well be the reason my car over heats. also, he said i have a coolent censor that needs attention that i can yank off any accord nd itl work(big plus) he also told me the reason my gauges were jumping was bc i have a bad ground somewhere so I am yet to seek that out.
Originally posted by HardInThePaintGirls should most definitely rep the shocker. Embrace the shocker.
Be one with the shocker.
My ride: http://www.cb7tuner.com/vbb/showthread.php?t=187897
