i searched and really didnt find anything.I have a 92 accord lx bone stock i changed the plugs and spark plug wires on friday i didnt have spark.So i took off the distributor cap and got a little bit of spark out of it.The car was running all weekend.I went to work yesterday the car started up fine everything was normal.I went out this morning to get ready for work my started right up and died.When i tried to start it back up it just cranked i dont know if its the distributor cap or the distributor itself. Please help any information will be helpful
92 accord keep losing spark
Just because you have some spark out of your cap doesnt mean its fully functioning...heres a simple test to see if your cap is getting the necessary spark to your wires
get a test light and remove your wires and remove the wires off the cap and touch each one of the caps electrodes meanwhile you have someone try to start your car (all wires disconnected) and go from electrode to electrode if you see the test light light bright intermitantly on each and everyone of the electrodes then you have spark and if not then you might want to replace your cap n rotor
Check Ignition Coil.1st car: Frost White 1991 Accord EX sedan.. (Dec. 1999 ~ Jan. 2001) *Sold*
2nd car: Black Pearl 1993 Accord 10th Anniversary sedan (Feb. 10, 2003 ~ Mar. 8, 2008) *Sold*
3rd car: Frost White 1992 Accord EX sedan (Jan. 15, 2008 ~ Aug. 12, 2008) *RIP*
4th car: Seattle Silver 1991 Accord EX coupe 5MT (Aug. 13, 2011 ~ Mar. 19, 2014) *Sold*
5th car: Black Pearl 1994 Accord LX coupe 5MT (Mar. 1, 2014 ~ )
also check the ignitor if thats bad it will have a no spark or week spark.this was put together by evil_demon_01 . You can also fined all this and more by him in the Common Beginner Technical Info can be found in here. PLEASE READ HERE FIRST
Car safety checks
Fluid Capacities
Originally posted by Cb7sex View PostThe icm is the ignitorthis was put together by evil_demon_01 . You can also fined all this and more by him in the Common Beginner Technical Info can be found in here. PLEASE READ HERE FIRST
Car safety checks
Fluid Capacities
