My driver's side wheel bearing is going bad. I thought I would be doing the ROH but it seems the deal has fell through. So I don't have the money to do the conversion with new parts. So I was thinking of keep the capture rotors as I don't think mine is that bad to take off.
The advice I need is if my driver's side is bad, should I do just that side or go ahead and replace both sides?
I found a bearing already pressed on the hub on Ebay for $60. This is the best I think as the bearing alone is $40 and the shop probably wants more than $20 to press the bearing in.
Any one here actually used this type of setup with Ebay bearing already pressed in the hub and last more than a year?
I have recently tested the suspected bearing and no play when tugging on the wheel. But I think it's going so it's a matter of time. I don't want to drive it too much before repairing it.
I just got my car broken into and stole my amps and sub. Lucky my touch screen was not stolen. So I need to save up for my music. It's not a good time as I have been unemployed for almost a year now.
Thanks.
Thanks.
