Car Overheating
    Car Overheating
    I have a 1992 Honda Accord Ex and about a couple weeks ago whenever it would idle for a few minutes it would overheat but when I took off it would cool down. I checked the coolant and I was really low so I filled it up and also got a new radiator cap thinking that was the problem. Just today my car started overheating again when idling.
    Any Ideas???
    Sounds like your fans are not working, are they turning on?
    You need to find where the coolant is going, something is wrong.
      yes at least 1 fan i know of is turning on....and im not leaking any coolant....at least I dont see a puddle or smell it
        Any Ideas???
        That's usually a sign of a failing water pump.
          really? would their be any other signs of a failing water pump
            could be the temperature switch or an air lock seen has how you just put coolant back into it.
              First you need to figure out where your coolant is going. That is just a symptom that is usually associated with a failing water pump, not saying it IS the pump, but very likely.
                how could I figure out where the coolant is going?
                  it could also be a blown head gasket leting exaust into the cooling system . ive had this happen . look for bubbles that keep come up in the coolent and dont stop. also check for like a brown stuff on bottom of rad cap it will be a silky filling and milky looking goo .
                  Car safety checks
                  Fluid Capacities
                    well when I changed the radiator cap there wasnt that brown stuff on it and i can hear my coolant bubbling but I just thought that was from it getting hot
                      Also my car like surges or misses out when I first start it for the day but then comes out of it once it is warmed up
                        Thats because your coolant system is low/has air in it.
                          ok.....well how can I check if it is a failing water pump?
                            Well first we need to find out where your coolant is going. You need to go rent a coolant system pressure tester from like Autozone or O' Reilly's, and find where the leak is.
                              any up dates?
                              Car safety checks
                              Fluid Capacities
