Clutch problem?
    Clutch problem?
    here it is.After my cb9 was down for over a month because the old tranny went bad on me,yesterday i got it out with an h22 tranny but right away i notice it was really hard to put it in gear . i had to push it in really hard for it to go in gears but rolling wasnt as bad.(when the car is off i can go through the gears like nothing). A friend of mine who is a long time member in here sujested for me to re-bleed the clutch an adjust the clutch pedal. So today when i got home from work got right on it but insted of it getting better i just got so bad that is not drivable .i just replace the slave cylinder in it since it wasnt building much pressure. My clutch consist of an act stage 2 (yellow) and a oem disc. any help pleasse, by the way is a non lsd h22.
    check ur lines the one da come from inside to the trany the one tha change gear s..sometimes those get twisted i hat the same proble
      shift linkage? if so how come when the car is off i can shift smoothly?
        when ever u press the clutch pedal how much does the slave sylinder come out?
          about average
            theres da bar da press the plate on the clutch try to move da one all the way back nd get someone to press the clutch like 3 time nd bleed it nd c if da works do it like 2 time
              http://www.cb7tuner.com/vbb/showthread.php?t=178908
              "Help me" is not a descriptive title, Next time I will delete it.
              My 5.7 LS1 Holden Ute
                Sorry boss !! O_o
                  instead of bleeding the clutch like a brake system, try bleeding it backwards, it works a lot better. you can get a hand pump and some rubber or plastic hose and push the fluid back to the master and into the reservoir. make sure your clutch pedal is adjusted correctly. check your linkage at the trans to make sure there is no binding in the bushings or cables.
                  Hey yo uhhhhhh fry man!!!!
                    I still can't bleed it , I replaced the slave and master and still can't get it to build pressure. What should I do or check next??
