No brake lights.
    No brake lights.
    Ok problem: no brake lights
    Things I've done so far: check all the fuses, replace the brake light switch.*
    Still nothing. Is there a relay or something.... Something that I'm missing
    Did you check your bulbs? Some times they're bad even if they look ok. Also if the bulb sockets are corroded you'll have problems. And also check your wiring.
    BB6->http://cb7tuner.com/vbb/showthread.php?t=200445<Summer Lover
    BD6->http://cb7tuner.com/vbb/showthread.php?t=194262<Dailey/Future AutoX
    Mazda 6s->http://cb7tuner.com/vbb/showthread.php?t=201313<Wifes
    CB7->http://cb7tuner.com/vbb/showthread.php?t=189108<Sold
      if heavy corrosion in sockets ,,check the tail light sensors ,which are mounted with your tail light assys
        Often times, the tail light sensors will fail like cb7attack66 said above. They’re pretty easy to take apart and re-soder. I would look at the connectors- sometimes they will short out if they are exposed to water too. It might be worth your time to take a look at the large reddish connector at the top of the left rear fender well that (I believe) has all of the brake wiring going through it.
        MRT's:
        2001 Acura CL
        1991 Honda Accord SE
        Originally posted by Bad_dude
        If you turn it all the way counter clockwise, you activate the after burner full throttle. Lol. Then when you press it, boom, fast as the T-Mobile data plan chic.
          Also man i was just wondering if your trunk leaks? If so that may have toasted some wiring. Just a thought, keep us posted. Good luck
            Especially if your tail-light seals leak. That’s what fried my two left brake lights and CHMSL. Running lights would turn on but nothing else would.
            MRT's:
            2001 Acura CL
