That's what I've heard on BITOG. MaxLife, or pretty much any brand name Dex, is $6.XX a quart at my AutoZone. You can prob get it or something comparable for cheaper if you buy it by the gallon or shop around.
What automatic transmission fluid would you prefer
Originally posted by kinguin7 View PostThat's what I've heard on BITOG. MaxLife, or pretty much any brand name Dex, is $6.XX a quart at my AutoZone. You can prob get it or something comparable for cheaper if you buy it by the gallon or shop around.
I had the same Question about using Valvoline max life in my Auto Trans and I found this on another Site saying Not to use it and to Only use Honda atf is this True or can I use Valvoline in it?
The link http://honda-tech.com/showthread.php?t=3009292
Originally posted by Purple91ex View PostSo can I use b&m trick shift I run that in my v8 blazer can I run that in my cb with out any problems an why were talkin about all this what would be best to run in wifey 04 civic ex auto transthis was put together by evil_demon_01 . You can also fined all this and more by him in the Common Beginner Technical Info can be found in here. PLEASE READ HERE FIRST
Car safety checks
Fluid Capacities
Originally posted by kinguin7 View PostA lot of people say Honda only, others say that MaxLife is better. I doubt many people actually know what's better, it's usually anecdotes. Many people have used Dex/Merc fluid without any apparent negative effects.
Originally posted by Purple91ex View Postok so just so im striaght on this i can get any 5 speed trans out of a 90 to 02 accord or 92-02 prelude will they all bolt up to my f22a4My Members' Ride Thread - It's a marathon build, not a sprint. But keep me honest on the update frequency!
Originally posted by SWMO View PostThis isnt a bad choice. Again, ive been doing this for 4 years and went to school for it while i was working the first 2.
Stay away from "house" brand universal fluids. They say they will work in every vehicle ever made without a CVT pretty much. I have seen premature failures when using these.Last edited by mr_cb7; 07-13-2012, 01:22 AM.
1992 Accord LX 4-Door Automatic 360000+KM Mileage
"If it speaks Swedish and it needs work, it's going to be expensive."
Originally posted by Andre93 View PostI had the same Question about using Valvoline max life in my Auto Trans and I found this on another Site saying Not to use it and to Only use Honda atf is this True or can I use Valvoline in it?
