hi my names luis. i have a 91 accord lx coupe. im working on an h22a swap with a t2w4 transmission. i jus wanna know if anyone has any suggestions from experience what clutch i should use. the motors gona be stock with some bolts ons to give it a little more power. stronger internals and head work are after i get it all together and running. (after having some fun that is lol). i think a stage 3 would b too much cuz i dont want a clutch thats going to have to be redone again quickly. from what i here stage 3 wears alot quicker than normal so whats your suggestions?
best clutch for h22a setup?
When I posted here asking about the same question, I bought an exedy clutch kit from ebay for about $110 with pressure plate, throwout bearing, clutch and alignment tool.
edit: also I don't think you need anything more than a stage 1 clutch unless you plan on putting a turbo, or modifying it a lot...Last edited by Amiss; 08-16-2012, 10:20 PM.
Originally posted by Amiss View PostWhen I posted here asking about the same question, I bought an exedy clutch kit from ebay for about $110 with pressure plate, throwout bearing, clutch and alignment tool.
Nice tranny choice. I have a exert stage 1 and 8lb flywheel on my h22a2013 Ice Cream Cruise!
VIDEO: 2012 Ice Cream Cruise
VIDEO: 2012 Ice Cream Cruise part 2
The single largest cruise in the Midwest!
August 3 ~ Omaha, NE
By 1320 Video
Member's Ride Thread
Exedy Stage 1 and Fidanza 8lb flywheel. I've got over 50k hard miles and tons of 8k rpm shifts on mine and its holding up fine. The clutch you can find for 260 shipped and I think I got my flywheel for 155 shipped, both off Ebay about 4 yrs ago.
I chose a different route meant for streetability and precision to hold up to like 350whp which wasnt necessary. This was the setup I was using on my h22 when I first decided to boost it. I was using a act clutch heavy-duty street/strip sprung hub disk on a 11.5 lb steel chromoly flywheel which was and still is excellent.
It will have a little heavier pedal pressure use than most but nothing extreme. It held up to alot of abuse burnouts you name it and even outlasted my transmission until I had to get it rebuilt by gearspeed.
My only gripe with those clutches dont use their throwout bearings ever! youll be replacing it the very next week if you do. So remember to try to get a stock replacement before using their throwout bearings they are complete utter trash.
Absolutely. Sparkle is totally right about the throwout bearing. Get a brand new throwout bearing from Honda, no matter what clutch kit you use.
Use a kit that is rated for your expected whp. An H22A with minor bolt-ons will need nothing more extreme than a stock replacement, or a "stage 1" from most reputable manufacturers. Anything more is just a waste, and more extreme friction material on the clutch disc will only eat your flywheel and pressure plate friction surfaces faster (just as aggressive brake pads will eat your rotors faster.)
Exedy and Daikin are both OEM manufacturers, and either will be affordable, reliable, and well suited to your application.
If you choose to go with a lighter flywheel, I suggest 11.5lbs, rather than the super-light 8lb you often see. 11.5 will be noticeable, but you won't risk stalling every time you're not perfectly coordinated with the gas and clutch. REALLY light flywheels can be a pain in the ass for a daily driver! I had an 11.5, and I was happy with it (and I did stall occasionally even with that! Usually just brainfarts, though...)
oh and just fyi, an Exedy Stage 1 has a 260 ft-lb torque capacity, so you could even run a 75 shot w/ all the bolt-ons and still be fine
i went from an exedy stage 1, with a stock flywheel, then i swapped it with a stage 2, and 11.5lb flywheel with minor bolt ons, a little more then exhaust and intake, people say you dont need it, but to me it grabs better, and u just tap my pedal and it grabs, its not hard at all, and also the stage 2 is my daily.
Originally posted by deevergote View PostWhat you "like" and what is proper for the function of the vehicle are not always one in the same.
Clutches are like condoms. Use what is appropriate for your equipment. Not enough will break too easily. Too much will be useless.
Originally posted by Mt.HOODrat View Posti like that. i better get one of those Magnum clutches...
