Originally posted by Mt.HOODrat
View Post
Seriously though, just like a condom, you want it to fit your equipment.
A weak clutch, like an old stock unit, will disintegrate in a matter of days with the added torque of even a low-boost turbo setup. That's like a teenie-weenie condom breaking when you stuff your average sized sausage into it. No good.
The right clutch, like the right jimmyhat, will provide the performance you need, and it will do it with minimal compromise.
A clutch that is too much for your setup is like sticking your little peeper into a Magnum. Not only will it get you laughed at by anyone that knows what you did, but it will also be too much for your equipment. The end result, while probably not as life-ruining as with using too little, will still be an inefficient use of the item at hand.
Bottom line, if you make 170whp, get a clutch that will handle 170whp (or a little more.) You don't need a clutch that will handle 500hp.
