Funny question but true. Anyone had a problem replacing theirs? Mine broke in half, I got it out, and went to 5 auto parts stores for a new one. Each store listed the same OEM replacement part BUT it's to big. One place even gave me a universal to try but no luck. Its a stock radiator, and it seems it's different than all others?? Help before I just put a whole new radiator in it that I don't need!!!! It's a 93 dx sedan 5 speed.
Radiator drain cock?
this is for the Denso radiatorOriginally posted by TypeG View Postpetcock. if it is a stock rad, then it sounds like you need to get it from a honda dealership. later.
19011-PH1-621 BOLT, DRAIN (DENSO) , BOLT, DRAIN
Car safety checks
Fluid Capacities
Before I order a new one is there anyway to see if radiator is aftermarket or stock? If advance auto, auto zone and orileys showed same plug that didn't fit, maybe mine has been replaced? It could be 19 years old?Originally posted by Accord problems View Post
as far as i know there is no real way to tell . unles its chrome and small.Originally posted by Judy5150 View PostBefore I order a new one is there anyway to see if radiator is aftermarket or stock? If advance auto, auto zone and orileys showed same plug that didn't fit, maybe mine has been replaced? It could be 19 years old?this was put together by evil_demon_01 . You can also fined all this and more by him in the Common Beginner Technical Info can be found in here. PLEASE READ HERE FIRST
Car safety checks
Fluid Capacities
Look for stamping's (Brand or part number) on the plastic molds. Other than that i wouldn't have any other suggestions besides maybe the radiator cap if it hasn't been changed.
02 Crv
Car safety checks
Fluid Capacities
well the radiator has a cap with an S branded on it. So its more than likely aftermarket. So, where the hell am i gonna get a petcock for a aftermarket radiator, considering this one and the stock one are different sizes? Any idea? It sounding more and more like im gonna be stuck with putting a radiator in this thing.....
Post up a photo of what you have with a scale on the back ground. Measure the dimensions, too. I have a non-OE radiator removed from my Civic because it was leaking. If the drain valve is a match with what I have, I can send it to you.
I don't feel like sending it for the sake of you to just try. Specially, knowing that you went and tried 5 stores to find the right plug yourself.
Since you don't have the original plug to size up, I measured what I have. As I said, this is from NON-OE radiator for a Civic. You claim to have OE radiator on your Accord. This plug may not fit. But anyways here are photos.
Now go on measure what you have as best as you can. And post up here your results.Last edited by oyajicool; 08-30-2012, 09:20 AM.A&P-IA
