About two months ago my CB broke down and wouldnt start due to no spark, so I thought it might have been the distributor cap, rotor, ignition coil, or spark plugs, I replaced all of those and no start, so then the last thing was the ignition control module which I then replaced and bam it started!! It was running great for about a week but after that when I would get in high rpms (above 3k) it would start to almost surge but it was different, acceleration would cut out and sometimes my car would just die, so I thought it had something to do with timing so I timed it, that didn't work either, so I cleaned the IAV valve ... Nothing. It is definitely something with missing a cylinder but I'm not sure what to do anymore. What parts do I need to replace?? Any ideas or help would be greatly appreciated thanks!!
Surging Issue
9 CYP - cylinder sensorOriginally posted by G102294G View PostYes ive got a CEL code reading code 9
found here : http://www.cb7tuner.com/vbb/showthread.php?t=212591997 Ford Explorer V-6 AT (what a piece of junk)
1993 Nissan Sentra M/T (front end damage, off road for now)
1999 Mercury Mountaineer V-8 A/T - RIP (rolled: totaled)
1992 Honda Accord A/T EX - RIP (transmission shot: sold to junkyard)
Car safety checks
Fluid Capacities
Did you replace the distributor yet? there is no cure for code 9 the dizzy will need replaced like said above.
Also a loose or short in the injector wiring and clip can cause a CYP cel, i've had it happen 3 times no need for a mechanic just yet IMO.
02 Crv
