my cb is smoking!?
    my cb is smoking!?
    i have a 93 honda accord lx. its been runnin pretty good since ive got it but bout a week ago my car started smokin. like a light grey smoke. not exactly what the problem. oh nd its burnin quite a bit of oil. i dnt know exactly where to start with this. i had a buddy tell me it was my valve stem seals. and if so how wud i fix this? im wantin to get this fixed before i start my dsm turbo setup.
    any comments or solutions wud be greatly apreciated.
    best thing is to do a compresion test and a leak down test . then report back.
    Car safety checks
    Fluid Capacities
      and exactly what would need to be done?
      it hasnt lost much power. still drops camaro ss and the new silverado and onther hondas with vtec but its just when i ''floor it'' thats when i see a small puff of smoke. i thought it was because im runnin on a prelude ecu but the ecu its got is from a f22a1 since dohc and sohc have different firing orders.
        Sure it does...
          yep
            The engine is burning oil and smoking. It is good time to overhaul the engine especially you are installing a turbo on it.
            As they say, the engine would have to come apart for internal parts up grades anyways if you want your engine to last with turbo.
            A&P-IA
              ^ Lol
              10th Anniversary Accord.
              05 Audi A4 Ultra Sport 6MT.
                Sounds like you have along road ahead of you to Turbo that thing. Better get some tools and read up on the stickys.
                  You need to take it to someone mechanically minded to do a compression test. There's more involved than just popping a gauge in your spark plug socket.
                    grey smoke is a headgasket.blue smoke is oil..
                    my new turbo build
                      Originally posted by dj_ender View Post
                      Sure it does...
                      Car safety checks
                      Fluid Capacities
                        White smoke is a head gasket. Blue is oil. Black is fuel. Gray is usually condensation... steam.
                        If this thread continues to be useless, it's getting deleted.
                          thanks for the replys fellas!
                          its not a head gasket cuz i had a 92 integra ls and i blew the head gasket on it and it was a big difference in performance and had almost no compresion. and my coolant would disapear. it idles right under 1k. but when i take off it wants to bog out.
                          the other question i had was if it could be that it needs an oil change or tranny oil change. i read somewhere that the tranny fluid when its low or needs replaced it will throw a greyish smoke.
                          my main question is how long can i drive it like this for cuz its my ride to work and skool.
                          once again thank you for the replys and help.
                            ok the tranny is in no way hooked up to the exhaust. you dont know how to do tube seals yet you wanna put a dsm turbo on. our cars can not in stock form beat a camero ss unless its on blocks.
                            so far you have ignored the advice given to you. do test and use your findings to tell you whats wrong.
                            also you need to be detailed in your findings and what the symptoms are.
                            for instance. is it a greyish smoke only when you start your car or is it all the time. maybe you have a head gasket problem and a fuel problem causing grey smoke and should get another car.
                            with out you doing a compression test or looking down your tubes where the spark plugs are and just saying i read her i read there we cant help you. so please go and do test. are you throwing codes? good luck man.
                            Accord SE
                            93se
                            Members Ride
                            Bought from: H22wagon93, Theos92VR4, Hondafan81, Father Time, DarkHusk, Gunrunner, FamousFreak
                            Sold to: sulimed, BurtonRiderT6, tishock
