temp gauge stuck dose not move how to fix
    my temp gauge dose not move any more how can i fix this? is it an athome job i can do or is it extensive work that needs to be done by mechanic
    Check the single red wire under the dist. Make sure its plugged in all the way.
    COUPE K24
      could not find a red wire under the dist would it be in a diff spot on a cb9 (wagon)
        I would say you need a temp sensor or a temp gauge. I would start with the temp sensor first. Yes, the temp sensor is located under the dizzy. Which one under the dizzy, I forgot Some one else please chime in to confirm.
