Hello I Recently Bought A 1993 Honda Accord LX And I'm Having Some Transmission Problems. When I Turn The Key To Start It The D4 Light Blinks And When It Shifts Into 1st Gears There Is A Little Kick. I'm Hoping Its Not Really Bad And If Someone Knows What's Wrong. I've Read On The Forums That When The D4 Light Blinks Then It Has Something To Do With The TCU, But Will That Cause The Car To Shift Rough?
Try another TCU or fix it by using the thread by cloudsac. I typed TCU fix on the search bar and found it in 10 seconds. This happens a lot with our auto accords. Try this and see what happens.
http://www.cb7tuner.com/vbb/showthre...hlight=tcu+fix10th Anniversary Accord.
05 Audi A4 Ultra Sport 6MT.
before you go buy another TCU, try pulling TCU code first to help narrow it down.Originally posted by 10thAnnivCB7 View PostTry another TCU or fix it by using the thread by cloudsac. I typed TCU fix on the search bar and found it in 10 seconds. This happens a lot with our auto accords. Try this and see what happens.
See the procedure found here: http://www.cb7tuner.com/vbb/showthread.php?t=179566
Basic summary of what you'll do (BUT LOOK AT THE PROCEDURE ON THE OTHER THREAD!!!)
1. Basically passenger side floor, remove kick panel, theres a blue connector.
2. Jump the connector with a paperclip.
3. Turn key to "On" (BUT NOT START)
4. "D4"" light will flash, count it and see what the code means.
