Redline at 4500rpm
    Redline at 4500rpm
    Ok So My Friend Bought A Cb A few Months Ago it Was Running Fine but a Few Days Ago it started to run a little funny the car wont pass 4500 rpm And has The CEL light on and when it hits 4500rpm it sounds like it's redlining he's also having trouble at start up he has to give it half throttle at start up any ideas on what it can be will be greatly appreciated
    thanks
    read cel
    A&P-IA
      What's the CEL?
      http://www.cb7tuner.com/vbb/showthread.php?t=21259
      If there's a CEL, something is WRONG. Nine times out a ten, fixing the CEL will fix whatever issue you're having.
        Wow i Feel Dumb Sorry Guys Completely forgot about reading the CEL, So i am going to call him so he can bring the car tomorrow so i can jump the pins and see what i get as a read out,, And Let you guys know What i Found ok
          Originally posted by JoshM View Post
          What's the CEL?
          Thanks i did needed to Know What Were the numbers to what problem i lost my hanes repair manual
            Is it stock motor? My friend swapped an F22b Sohc Vtec motor and that would happen because he didn't have the right ecu or Vtec wired
            1993 10th Anniversary MRT
            Originally posted by The G-Man
            For that money, yes. But my dick isn't big enough for that shit.
            List of all my cars to date
              It's a Stock f22a1..
                A CEL will usually cause the engine to run in "limp mode"... and you should never rev an engine throwing a CEL high anyway. That's just asking for a blown engine! It's like feeling a pain in your ankle, and then deciding to run as fast as you can.
                Whatever is throwing the CEL is likely the culprit, or the CEL itself throwing the ECU into limp mode. However, the valve timing may be off (belt skipped a tooth), or the ignition timing may be way off.
                  You should find out if you're friend has had any type of swap, or major work done. Sounds like It's running in open loop. So if the motor and everything under hood is basically stock, then start with checking the o2 sensor. especially if the code happens to be a 41. If he has had a swap or anything done... then start looking into bad wiring/splices etc. It's really common to have an old poorly twisted and taped splice, fall apart.
                    yes the cb is stock original engine and tranny..
                    8 -TDC - top dead center sensor
                    15- Ignition output signal
                    these are the two codes it gave me .. when i read the blinking lights so i asked him if he had change the distributor, and he said yes cuz his car was stolen and the just took a few thing off the car including the distributor so he got one from the junk yard so i told him was the car running fine before and he said yes in till he put a use distributor on it. so we all this info i came down the conclusion that he has to go exchange the used distributor or get a refund and buy a new one..
                    Also The D4 light was blinking when i jump the plug to check the codes so does the part that is wrong with the engine wich is the distributor effect the tranny also.. is my question
                      Once you fix the distributor everything should go back to normal
                        That's What i Am Hoping ,, let's see once we go tomorrow and exchange the old distributor for one that is actually good and to save us the hassle i told him we are gonna swap it out right there in site just in case we get the bad luck of another faulty dizzy ..
                          Swapped out the Dizzy For A Exchanged one From the JY And Problem Solved
                            Every once in a while when i start my car.... the CEL will trigger and i redline at approx 4500 too. but my rpms are off so idk for sure. its really weird. it runs fine other wise... but redlines at 4500ish. scared me the first time it happened. getting on the freeway... whole car jerking lol. fun times...
                              You're not "redlining". It's a fuel cut. A safety measure programmed into the ECU to prevent (or try to prevent) engine damage. Fix the problem the CEL is alerting you of, and the 4500rpm fuel cut will stop.
                              GARGOLA88, start typing with caps lock off, or you're going to find your posts are getting deleted.
