trailing arms
    trailing arms
    does it matter if trailing arms i pick up come out of a 4 dr/2 dr 4 or 6 cylinder? my 91 doesnt have a sway bar and i was just going to buy rear arms that had the hole so its all bolt on.
    There is no 6 cylinder....
    The only difference in the arms is the bolts.
    To get the sway bar, you'll need to swap that rear crossmember.
    MRT
    sneaky motherfucker
      Just like Geoff said, your arms already have the sway bar end link holes.
      Instead of buying an OEM sway bar and crossmember from the junkyard I'd recommend just getting a Progress rear bar. I spent $180 on mine and it's probably the best rear bar you can get for these cars. The Accord OEM one is a hollow 14mm unit and the ones you can find on the '97-'99 CL, '92-'94 Vigor and '96-'98 TL are all hollow 16mm units. The 16mm was definitely an upgrade over the stock CB bar but I can't wait to put the Progress on.
