Hi guys I am new to cars and working on them, I own a 99 accord I recently picked up a 91 accord for $400 that is in need of some TLC. It came to my attention that the cooling system was filled with crap when I tried to fix the erratic idle issue.
To make this short and sweet, the engine block is filled with rust. I poured some distilled water and vinegar in it, but it didn't do much. I read that CLR/water should do the trick, but I was wondering if I shouldn't use my power washer to blast some of the crap out of the block's coolant passages before I dump some CLR and water in it.
Also, I already bought a new thermostat housing, the old one has the barbs half missing from rusting away, but should I buy new radiator hoses too, or will the ones that are on there be okay to reuse?
This is what the inside of the pipe going into the block looks like:
